optimization methods mentioned in your article
Posted: Sun Oct 09, 2011 1:52 am
Hi graeme,
I read your paper in 2008(the journal of chemical physics 128,134106) about optimizers. In that paper, it mentioned that GL-BFGS(hess) is faster than L-BFGS, but the qualitative error exists.
(1) Is that means that GL-BFGS(hess) is not stable and for some systems a big error may happen?
(2) Is IOPT=1 stands for GL_BFGS(hess) optimizer? Or is other L-BFGS(hess) or L-BFGS(line) mentioned in your paper?
(3) If there are many local minimum positions in potential space. And the two end images are very close, around 1A. In this situation, is the first-order methods perform more efficient than the second-order methods? Bbecause the distance of the diffuion atom in reactant and product is short, should I lower the TIMESTEP and MAXMOVE at the same time?
Thanks in advance!
Thanks in advance!
