Problem of Compilation of version 2.04
rlzhou
Post by rlzhou »
I tried to compile the VTST version 2.04 with vasp5.2.2. I want to use the solid-state neb method in this version. So, I changed the main.F file according to the instruction. When I compiled it, errors occur. The error message is:
mpiifort -FR -lowercase -assume byterecl -FR -O0 -c main.f90
fortcom: Error: main.f90, line 2611: The number of actual arguments cannot be greater than the number of dummy arguments. [CHAIN_FORCE]
fortcom: Error: main.f90, line 2612: The type of the actual argument differs from the type of the dummy argument. [B]
TSIF,LATT_CUR%A,LATT_CUR%B,IO%IU6)
fortcom: Error: main.f90, line 2612: The shape matching rules of actual arguments and dummy arguments have been violated. [B]
compilation aborted for main.f90 (code 1)
make: *** [main.o] Error 1
I checked chain.F, the subroutine CHAIN_FORCE does not contain dummy arguments as TSIF. So, I think the chain.F file included in the VTSTcode package is not that changed for solid-state neb. If it is right, how can I get the correct one?
Re: Problem of Compilation of version 2.04
I've uploaded a new version (2.04a) and checked that it is correct. The chain_force function should contain the stress variable:
SUBROUTINE chain_force(nions,posion,toten,force,stress,a,b,iu6)
