Image distance in Cl-NEB
kambiz
Post by kambiz »
I m trying to run a Cl-NEB for NH -> N+H. After using "nebmake.pl" and creating 4 images, I found that the N--H distance in image 1, is 0.35 which is very small.
My question is: Can I edit the position of H atom in image 1?
Of course the distances between images wont be equal. How does Cl-NEB deal with this?
Re: Image distance in Cl-NEB
No problem; you can edit the distances manually. The spring force will pull the images back into equal spacing (on either side of the climbing image). There should be no problem with the default settings, but if for some reason you would like the image spacing to relax more gradually, you could lower the NEB spring force from the default of 5 eV/Ang^2 to around 0.5 eV/Ang^2. But again, you should not have to make any modifications for a CI-NEB calculation in which you have manually adjusted the configurations along the initial path.
kambiz
Post by kambiz »
Thanks a lot dear graeme
Cheers
Kambiz
