how to visualize bader result with VMD
jiddy
Post by jiddy »
Hi I ran Bader on the gaussian cube file which contains charge density using the following command.
bader [cube file]
THe following three files were generated: BCF.dat; AVF.dat; ACF.dat. Is AVF.dat the volume file? How do I visualize it in VMD?
Re: how to visualize bader result with VMD
You can print the Bader volumes using the -p option and view the chgcar/cube style files. Each volume can be printed with a non-zero value in the volume and zero outside. Setting a low value for an isosurface in vmd will show you an outline of the Bader volume.
