DOS for Specific Group of Atoms
vimal
Post by vimal »
Dear All,
I am wondering how i should do the following in VASP.
I have 100 atoms, and wish to plot Density of states of only certain atoms.
(i.e. i need two DOS, one for atoms 1-50, and other for 50-100).
I know to get the Total DOS for all atoms using p4vasp,
but i do not know, how to work on this.
I am wondering how i could do this in VTSTscripts or any other tools avaialble.
Your suggestions are welcome and i thank you all in advance.
Jeyavimal
Re: DOS for Specific Group of Atoms
The dosanalyze.pl script allows you to specify a set of atoms over which the local DOS is calculated.
vimal
Post by vimal »
Dear Graeme,
Many thanks for your reply.
I used the dosanalyze script as follows
Step :1
~/vtstscripts/split_dos
which created a DOS file for each atom
Step:2
~/vtstscripts/dosanalyze.pl a 5,6
(by this command, i wish to plot the summed DOS for atom 5, 6).
I get something like this.
WARNING: band center has shifted by more than 10% compared to full integrated range
Total States: 263.84387368
Average Energy (band center): -18.8643453614152
Width at quarter-height: 0.666
Lower energy cutoff: -20.00520000
Upper energy cutoff: -17.00520000
Standard Deviation: 0.834251333964241
This is the only message i see from the script,
and i don't fine any files updated, nor created.
Therefore, my question now is
1) whether i am using the script in a right way
2) If so, where should i see for the Summed DOS for atom 5, 6.
Your help would be really appreciable.
Look forward hearing from you.
Vimal
Oh, my bad. The doslplot.pl script will combine the local dos and make you a plot.
