Reaction coordinates in NEB
kambiz
Post by kambiz »
Hi dear all,
I m checking how my NEB (compiled with vtst codes) is running. Using "nebef.pl" I got this:
0 0.00000000 -240.87926600 0.00000000
1 0.65641500 -240.49116500 0.38810100
2 3.31633700 -239.57548200 1.30378400
3 6.88612400 -239.14187900 1.73738700
4 5.65225700 -237.74746800 3.13179800
5 0.00000000 -242.46581600 -1.58655000
Does the second column represent the reaction coordinates? Should I increase the number of images?
Kambiz
Re: Reaction coordinates in NEB
The second column is the force projected along the path -- it is not the reaction coordinate.
Check the neb.dat file for more information including the distance between images. This distance along the path is suitable for a reaction coordinate.
You should also check the force on image #4. If the force on that image is going to zero, you have a good saddle. If you only care about the saddle, then you don't need to add images. On the other hand, if there is a problem with convergence of that image, you should add more images to better define the tangent along the path. But unless you have a complex path, using 4 images is a good start. That said, a barrier of 3 eV is pretty large. So (without seeing your calculation) it is either not converged or there is something unusual going on. Check the movie along the neb to make sure that it's reasonable.
kambiz
Post by kambiz »
Dear graeme,
Thanks for your answer.
My NEB hasnt converged yet, but it seems that there is a problem in Images #3 and #4.
This is neb.dat results:
1 0.000000 0.380322 -0.667939 1
2 0.000000 1.100327 -2.421587 2
3 0.000000 1.846962 -2.881634 3
4 0.000000 5.433248 -3.710341 4
5 0.000000 -1.586550 0.000000 5
This is the NEB part of my INCAR:
ICHAIN = 0
LCLIMB = .FALSE.
IMAGES = 4
SPRING = -5
LSCALAPACK = .FALSE.
EFIRST = -240.8744
ELAST = -242.4604
POTIM = 0.2
Can it be because of "POTIM" or "EFIRST/ELAST"?
I really appreciate your help.
Kambiz
cenwanglai
Post by cenwanglai »
have you compiled the vtstool code to the vasp?
rgarcia87
Post by rgarcia87 »
The problem comes from your POTIM parameter, which has a different physical meaning for IBRION = 3 than for IBRION 1 or 2.
For the decomposition of organic molecules on metal surfaces and IBRION=3 flag, either for relaxations or NEB calculations, values between 0.007 and 0.025 are usually safe and robust, and also converges faster than IBRION=1. That is, POTIM should be more than one order of magnitude lower than for IBRION 1 or 2. Do your own tests to find the optimal value for the system you are working with.
