What is the forces standing for in neb.dat?
Posted: Mon Mar 07, 2011 2:36 am
I have got a neb.dat read like below:
0 0.000000 0.000000 -0.010838 0
1 0.867271 -0.837088 -1.279897 1
2 1.768503 -1.026423 -1.128849 2
3 2.584773 -0.937171 -2.621561 3
4 3.429818 -0.846114 -0.975741 4
5 4.433803 -1.987181 -2.796546 5
6 5.509804 -2.035966 -3.951533 6
7 6.561177 -2.989551 0.890184 7
8 7.546694 -2.312575 -0.077526 8
(1)What does a positive or a negative force item mean in the fourth column? Do the plus or minus sign directs the movement of the images?
(2)The distance between two nearby images is supposed to be lower than 1 Angstrom?
(3)Can anyone give me some advice about the 7th line with the lowest energy? The 8th line has been relaxed to ground state and is supposed to be CO-adsorbed-slab Final State. And the first line stands for configuration that CO in the vacuum off the slab surface.
