CI-NEB not converging
ypochareddy
Post by ypochareddy »
Dear Professor,
I am working on a Mg, Mn, Ti and S system. I am having convergence issues. Could you please help me solve this? I have attached relevant files.
CINEB.rar
(20.58 MiB) Downloaded 1875 times
Re: CI-NEB not converging
Start by further minimizing your initial and final state structures - they do not appear stable to me.
ypochareddy
Dear Professor,
I rerelaxed the Inital and Final images with EDIFF = 1E-5 and EDIFFG = 1E-6 and then ran the NEB calculations but I am still having convergence issues. I have attached relevant files. Could you please advice me on how to proceed further?
[attachment=0]Step4_POTIM_Relax2.rar[/attachment]
(20.78 MiB) Downloaded 926 times
Your endpoints should be relaxed with the same settings as your band. You endpoints appear to be spin polarized with +U and your band has neither.
This may help. In the attached, I reconverged your endpoints (min1a.tar.gz and min2a.tar.gz) and then did an NEB calculation between them. I used more reasonable settings (regular potentials, ENCUT~300eV, KPOINTS=2x2x2, prec=Normal, LREAL=Auto) and was able to complete these calculations in a couple of hours.
I have said this many many times on this forum, but I will repeat here that it is much better to use a minimal set of parameters that will qualitatively reproduce the geometry. It is then trivial to reconverge your calcualtions with more accurate settings. In your case, you used +U and spin polarization for the endpoints with (in my view) far too precise settings of LREAL=False, prec=Accurate, _pv/_sv potentials, KPOINTS=5x5x5, ENCUT=500, but then turned off +U and spin polarization for your NEB with only 3 images. No. The way to go is to use modest settings to find reaction mechanisms and geometries and then increase parameters to efficiently determine the precision of your calculations.
neba.tar.gz
(9.51 MiB) Downloaded 1895 times
min2a.tar.gz
(1.12 MiB) Downloaded 939 times
min1a.tar.gz
(902.83 KiB) Downloaded 924 times
