A Cl-NEB and/or NEB must with a minus EDIFFG?
cenwanglai
Post by cenwanglai »
I always run a NEB or Cl-NEB with the EDIFFG<0.
But, I can not make sure that the EDIFFG<0 is set to scale the the forces between images?
Can I set a EDIFFG>0 (basing on energy) for the NEB/Cl-NEB run?
Re: A Cl-NEB and/or NEB must with a minus EDIFFG?
There is only one harmonic degree of freedom between the images; you should not worry about convergence along the band when using the force criteria. If there was a reason to change the tolerance of the image spacing, you can change the spring constant. But our suggestion is to use the force-based convergence criteria with the standard spring constant. There is no need to use energy, especially since it does not provide a meaningful and reproducible convergence criterion.
cenwanglai
Thank you so much!
