nebmovie.pl
lexa
nebmovie.pl
Post by lexa »
When I run the nebmovie.pl script I get the following message:
Using POSCARs to generate movie
sh: /export4/work/ht409/vtst/pos2con.pl: Permission denied
sh: /export4/work/ht409/vtst/con2xyz.pl: Permission denied
cp: cannot stat `POSCAR_TMP': No such file or directory
I would appreciate any help!!!
Alexandra
chill
Re: nebmovie.pl
Post by chill »
Is it possible that you do not have execute permissions for the perl scripts? Additionally if you ran the command "/usr/bin/env perl -v" does perl print out it version information?
Re: nebmovie.pl
Another check: did you download all the scripts into your vtst directory?
lexa
Re: nebmovie.pl
Post by lexa »
Dear Chill and Graeme,
I am using the other VTST scripts like nebmake.pl and nebbarrier.pl without any problems and I do have all the scripts in the same directory. Also when I run /usr/bin/env perl -v I get the version details: "This is perl, v5.8.8 built for x86_64-linux-thread-multi" etc... Confusing huh?!
Alexandra
Re: nebmovie.pl
What about write permission in the NEB directory? I assume these are your files, but if you were not allowed to write the output files for some reason, this could explain the permission problem.
