Calculating Charge Transfer using Bader Analysis
nzk116
Post by nzk116 »
I have a surface and a molecule above this surface. I need to calculate the charge transfer in VASP.
Are following steps correct?
1. Use special flags to get the correct CHGCAR that can be used in Bader analysis.
2. Calculate Bader Charge.
3. Do Step 1 & 2 for (a) Surface Only, (b) Molecule Only and (c) Surface + Molecule.
4. Charge Transfer = Bader Charge of (c) - Bader Charge of (a) - Bader Charge of (b)
Thanks for the help.
Re: Calculating Charge Transfer using Bader Analysis
Yes, that is correct. You can also compare your Bader charges to the formal charges on the atoms. For example, you know that the total charge on your molecule will be the sum of the formal charges on the atoms in the molecule, without doing (b). But, if you want to know how charges redistribute within the molecule upon adsorption, then (b) would be needed.
alex
Post by alex »
when I use the Bader analysis for the surface without adsorbate (a), must I use the electron density of the equilibrium surface or unrelaxed one?
This question is important because adsorption can significantly change the surface structure and these methods produce different results for the charge transfer.
Thank you in advance
Using the relaxed one would be better.
alex
Post by alex »
[quote="graeme"]Using the relaxed one would be better.[/quote]
Why?
