chg2cube.pl - strange result
yeops
Post by yeops »
Hi all,
I've been using the chg2cube.pl utility to convert the PARCHG file generated by VASP to the cube format to be read by Materials Studio. The chg2cube.pl utility has been working fine for me so far except for one case where the isosurface looks really strange: the isosurfaces on top and below the plane of atoms are sheared in opposite directions to one another. (Imagine a perfect sphere sliced in the centre with the top hemisphere displaced to the left and the bottom hemisphere displaced to the right)
I've used another program to look at the cube file and it looks the same, so I don't think it is the fault of Materials Studio. I've also used another program to look at the PARCHG file and the isosurfaces look fine too, so something must have gone wrong during the PARCHG to cube conversion process. Unfortunately I'm perl illiterate, so i can't look at the code to see what has gone wrong. If someone is willing to look at the files, I can post the PARCHG and corresponding cube files somewhere for download. Thanks in advance!
Re: chg2cube.pl - strange result
If you post a link or send us the file, we'll take a look. Without a precise format definition, we would like to output a file that is as compatible with other tools as possible.
yeops
Post by yeops »
Hi graeme,
I've uploaded the PARCHG file for my system and the weird looking cube file to ftp://ftp.ihpc.a-star.edu.sg/outgoing/yeops
Unfortunately the files are really huge so I can't keep them up for long. Please let me know when the download is done so that I may remove them.
Thanks so much for your help!
dano
Post by dano »
can you zip the file so it will transfer faster? We have been getting some time out errors
yeops
Post by yeops »
My apologies, I've zipped the files so the transfer should be faster now. Thank you!
dano
Post by dano »
Nice catch. There was a bug causing the script to skip numbers that ended in a period. The bug has been fixed. And the file has been updated in CVS.
yeops
Post by yeops »
Many thanks!
tarzan11_11
Post by tarzan11_11 »
Hi Yeops
Hope u still lokk at this forum ..
Can you pls giude how to plot the .cude files using materials studio ..
gaussview by itself is no good for plotting periodic systems ...
thanks
dano
Post by dano »
you should consider using vmd
yeops
Post by yeops »
Hi tarzan11_11,
Which version of Materials Studio are you using? As far as I know, you need version 4.4 and above to visualize the cube files. Do an "Edit | Insert from..." to load the cube file to the structure file.
Hope this helps.
tarzan11_11
hi thanks
we have MS 4.0
best wishes
