Simple question on installation of vtstscripts (export path)
Posted: Fri Jan 22, 2010 4:03 am
Dear everybody
I'm newbee in using linux system and the vtstscripts,,,,,,I read from http://theory.cm.utexas.edu/vtsttools/scripts/ the procedure to install,,,,,,,,it was stated that I need to
"adding the vtstscripts directory to your path"
so I add a line in my .bashrc like this
#this is for vtstscript
export PATH=$HOME/vtstscripts:$PATH
However when I try to run the scripts,,,,,,,,,it happen like this :
[revival@localhost vtstscripts]$ vasp2xyz POSCAR poscarxyz
bash: vasp2xyz: command not found
Is there something that I miss that I forgot to do???
I'm sure that I have perl in my mandriva system,,,,,,this is the version of perl :
[revival@localhost vtstscripts]$ perl -v
This is perl, v5.10.0 built for i386-linux-thread-multi
(with 1 registered patch, see perl -V for more detail)
Copyright 1987-2007, Larry Wall
Perl may be copied only under the terms of either the Artistic License or the
GNU General Public License, which may be found in the Perl 5 source kit.
Complete documentation for Perl, including FAQ lists, should be found on
this system using "man perl" or "perldoc perl". If you have access to the
Internet, point your browser at http://www.perl.org/, the Perl Home Page.
Thanks so much everyone that read my topic and give me a help
GBU
GBU
