problem related to the setup of images from nebmake.pl
Posted: Fri Dec 04, 2009 3:43 am
Hi, NEB users
I have a problem related to the setup of images from nebmake.pl. I really need your help so I may write a bit more about the situation. thanks for your time :)
The system i study has a substrate and hydrogen atom bonded to the substrate surface atom.
i have the optimized geometries of the initial and final structures as POSCAR1 and POSCAR2.
i then run the nebmake.pl POSCAR1 POSCAR2 6 and get the image POSCAR in 01,02...
However, when I view the POSCAR in the 03 directory, I find that some of the atoms(atoms that bonded with H and deformed vertically with respect to rest of the atoms) on the substrate surface shift so much that they are separated from the rest of the substrate(say the normal atom bond length is 1A, the distances of the separated atoms are 1.5A away from the rest atoms on substrate, so those atoms look like a cluster sitting above the substrate surface)
My questions :
1. I am wondering that whether this unphysical intermediate images structures will be a problem for the following neb calculations.
2. I want to know whether it is possible or reasonable to fix some of the atoms when constructing the intermediate image structures. By reading the current nebmake.pl code, it looks like they take the pbc_difference of all corresponding atoms of the reactant and product.
3 . Furthermore, can i manually construct the guessed intermediate image structures in POSCAR and put them in the 01,02... and run the neb calculations and let the vasp optimize and find the transition states structures
My questions :
