Use of ALGO=FAST, LREAL=A, NSIM=4 in Dimer/NEB
Posted: Mon Aug 17, 2009 6:27 am
I am attemtping to run some NEB/Dimer calculations with a large slab (181 atom total).
In order to make these calculations practical, I have been forced to add;
ALGO=FAST
LREAL=A
NSIM=4
to get any results at a reasonable time.
However I wonder what these settings will be doing to the code produced by Professor Henkelman and his group, in terms of convergence or reaching the correct transition state.
As of this moment one NEB calculation and two dimer calculations for the same path have also produced a qualitatively similiar transition state stucture but none have converged.
I had hoped (naievly?) that I could produce the correct TS with these settings and then corrected the energy with a subsequent calculation using default VASP settings.
Is it possible that the use of the 'fast settings' is stopping the calculation from proceeding correctly? Certainly it is making the calculation proceed more quickly. Or do I just need to wait for a longer time period for the TS to be found?
Many Thanks for any reply,
---Results of DIMCAR file for one calculation (resumed by replacing POSCAR with CONTCAR, and MODECAR by NEWMODECAR)---
Run: No1
1 0.93029 4.23658 -841.66558 -1.14820 6.88745
1 0.93029 4.04594 -841.66558 -1.33522 7.54077
1 0.93029 3.93909 -841.66558 -1.55116 3.99649
1 0.93029 3.33027 -841.66558 -1.58875 5.64526
2 0.76996 5.82522 -841.66937 -1.62759 7.69137
2 0.76996 6.19712 -841.66937 -1.78638 3.20428
2 0.76996 5.92385 -841.66937 -1.81422 1.61379
2 0.76996 5.83550 -841.66937 -1.82668 2.21946
3 0.87115 6.84286 -841.68563 -1.64484 -1.89902
3 0.87115 6.62387 -841.68563 -1.66639 2.38831
3 0.87115 6.82852 -841.68563 -1.66687 -1.04269
3 0.87115 6.78812 -841.68563 -1.66393 -0.12660
4 0.56593 7.51658 -841.69168 -0.17688 -5.26238
4 0.56593 7.51609 -841.69168 -0.15830 -1.58383
4 0.56593 7.57281 -841.69168 -0.13400 -0.12663
4 0.56593 7.57886 -841.69168 -0.13131 -0.04012
5 0.94247 7.64980 -841.69745 -0.71144 0.93606
5 0.94247 7.53578 -841.69745 -0.75951 -0.12281
5 0.94247 7.61227 -841.69745 -0.74188 1.08147
5 0.94247 7.62293 -841.69745 -0.80783 -0.37453
6 0.59822 7.73434 -841.70186 0.10583 -2.13714
6 0.59822 7.66185 -841.70186 0.11951 -0.44254
6 0.59822 7.68960 -841.70186 0.13066 -0.02770
6 0.59822 7.69122 -841.70186 0.12861 -0.05730
7 1.42741 6.65331 -841.69463 1.61149 -3.67174
7 1.42741 6.90839 -841.69463 1.64698 -0.48946
7 1.42741 6.78707 -841.69463 1.66903 0.20359
7 1.42741 6.91323 -841.69463 1.66389 -0.05350
Run: No2
1 2.61504 8.31185 -841.65323 3.46095 7.17148
1 2.61504 8.70025 -841.65323 2.47308 8.93185
1 2.61504 7.11221 -841.65323 1.69398 10.05366
1 2.61504 6.41413 -841.65323 1.25154 4.12855
2 2.96452 5.93151 -841.58078 0.88042 6.69672
2 2.96452 8.39693 -841.58078 0.77810 8.35420
2 2.96452 6.38603 -841.58078 0.34009 6.42709
2 2.96452 4.94667 -841.58078 -0.08053 4.34487
3 2.46190 4.58448 -841.64906 0.77501 9.79908
3 2.46190 5.80668 -841.64906 0.48672 5.39046
3 2.46190 4.75331 -841.64906 0.02254 2.77639
3 2.46190 3.52371 -841.64906 -0.17823 3.84788
4 1.76334 6.41776 -841.67902 1.23938 6.89719
4 1.76334 8.48847 -841.67902 1.26740 5.00503
4 1.76334 3.40856 -841.67902 0.99245 6.13151
4 1.76334 4.73352 -841.67902 0.94250 3.44075
5 1.80469 7.22108 -841.61309 -0.32111 12.30048
5 1.80469 8.14264 -841.61309 -0.61186 6.11802
5 1.80469 4.92011 -841.61309 -0.99815 6.81515
5 1.80469 5.46823 -841.61309 -1.11281 3.98679
6 1.97160 5.78832 -841.64270 -1.06581 14.36118
6 1.97160 7.07648 -841.64270 -1.36489 3.33882
6 1.97160 3.55540 -841.64270 -1.76720 4.23498
6 1.97160 3.35267 -841.64270 -1.91090 2.67489
7 1.62263 5.98730 -841.66725 -0.67812 13.81606
7 1.62263 8.25427 -841.66725 -0.70925 4.14955
7 1.62263 5.89056 -841.66725 -0.75888 4.81049
7 1.62263 5.30416 -841.66725 -1.36576 3.60098
8 0.78107 7.76665 -841.68870 -0.14496 13.34619
8 0.78107 7.38683 -841.68870 -0.35105 5.89227
8 0.78107 4.71578 -841.68870 -0.55597 5.69780
8 0.78107 4.57943 -841.68870 -0.69759 4.46563
9 0.66283 7.49425 -841.69482 -0.85882 15.97305
9 0.66283 9.51917 -841.69482 -0.66620 4.15247
9 0.66283 6.21579 -841.69482 -0.83140 3.78268
9 0.66283 6.59462 -841.69482 -0.99738 6.89302
Run: No3
1 0.72993 9.94363 -841.69947 0.71889 10.94416
1 0.72993 12.92972 -841.69947 -0.04371 11.57521
1 0.72993 7.98453 -841.69947 -0.36732 2.19454
1 0.72993 6.73489 -841.69947 -0.47136 2.18831
2 0.40371 9.89070 -841.70129 0.40813 3.10282
2 0.40371 10.17441 -841.70129 0.32200 4.73522
2 0.40371 11.87498 -841.70129 0.33368 5.83648
2 0.40371 12.41256 -841.70129 0.44366 1.06109
3 1.61062 12.60386 -841.68798 2.75647 2.70587
3 1.61062 11.79408 -841.68798 2.73943 3.05205
3 1.61062 10.48933 -841.68798 2.61704 2.83768
3 1.61062 9.44270 -841.68798 2.45680 2.43934
4 2.84345 8.35024 -841.61147 3.90909 2.66987
4 2.84345 8.06435 -841.61147 3.85312 4.63246
4 2.84345 8.97426 -841.61147 3.48812 7.91011
4 2.84345 10.32518 -841.61147 3.36929 12.80998
5 2.92773 11.05383 -841.46629 3.08306 10.97800
5 2.92773 10.13407 -841.46629 2.92012 11.14227
5 2.92773 10.42716 -841.46629 2.88057 18.43009
5 2.92773 11.96853 -841.46629 2.94386 43.11650
6 3.93549 14.27979 -841.28190 4.56058 57.13172
6 3.93549 11.93295 -841.28190 3.97326 61.48398
6 3.93549 9.21658 -841.28190 3.26823 60.92482
6 3.93549 7.33502 -841.28190 2.59981 60.13447
7 4.23884 7.82969 -841.03882 2.91808 58.72140
7 4.23884 5.20232 -841.03882 1.25080 28.80764
7 4.23884 8.82547 -841.03882 0.57005 6.04428
7 4.23884 4.81322 -841.03882 0.03926 3.60428
Still proceeding...
ALGO=FAST
LREAL=A
NSIM=4
Run: No1
Run: No2
Run: No3
Still proceeding...
