CI-NEB calculation vs. NEB calculation
Posted: Thu Jul 30, 2009 1:47 pm
Dear users,
I have been comparing the output from a NEB calculations and one from a CI-NEB calculation for the
dissociation of a NO molecule on a Pt surface.
The result from the neb calculation, as obtained using the nebbarrier.pl script is:
1 0.904029 0.502353 -1.203445 1
2 1.809576 2.242689 -4.132918 2
3 2.716485 2.012534 0.927999 3
4 3.624264 1.392145 1.313531 4
5 4.530816 0.790637 0.156333 5
6 5.437633 0.346388 0.000000 6
While the result from a ci-neb calculation (starting with the final images from the neb calculation) is:
1 1.807779 0.347128 -0.671574 1
2 3.619005 2.084444 -0.002807 2
3 5.031200 1.407191 0.035186 3
4 6.443959 0.897233 0.370033 4
5 7.857079 0.859869 0.492205 5
6 9.270229 0.346388 0.000000 6
I find this strange, since path is now much longer with a CI-NEB calculation and the CI-NEB now gives a smaller barrier. The INCAR file is (for the neb calculation):
SPRING=-5
IMAGES=5
ISTART = 0
ICHARG = 2
ENMAX = 400
ALGO = V
EDIFF=1E-4
EDIFFG=-0.030
LREAL=A
ROPT=3*0.0005
NSW=600
POTIM = 0.1
ISMEAR=2 ; SIGMA=0.2
SMASS=1.0
LWAVE=.FALSE.
LVTOT=.FALSE.
IDIPOL=3
LDIPOL=.TRUE.
LCLIMB=.FALSE.
LCHARG=.FALSE.
The only thing that I can think of is that the linear interpolation between the initial and the final state is not very accurate, resulting in a bad initial
guess of a transition state. As a consequence the neb calculation does not give a very accurate estimation of the minimum energy path. Is this correct or
is there something I am not considering correctly?
Thank you in advance for your answers.
SPRING=-5
IMAGES=5
ISTART = 0
ICHARG = 2
ENMAX = 400
ALGO = V
EDIFF=1E-4
EDIFFG=-0.030
LREAL=A
ROPT=3*0.0005
NSW=600
POTIM = 0.1
SMASS=1.0
LWAVE=.FALSE.
LVTOT=.FALSE.
IDIPOL=3
LDIPOL=.TRUE.
LCLIMB=.FALSE.
LCHARG=.FALSE.
