a problem with using akmc.pl
Re: a problem with using akmc.pl
Is akmc.pl in your path and sitting with the other vtstscripts? The problem may be that you downloaded that script separately.
Download the full set of vtstscripts and untar them into a directory which is in your path. Then you should be able to run any of them from any directory.
