bugs in neb code
ezanardi
bugs in neb code
Post by ezanardi »
I've found two bugs in neb code
1) In tsase/neb/util.py vproj(v1,v2) it has to divide by the square of the modulus of v2 ,
but currently it divides by the modulus of v2. A patch to fix that bug (just changing vmag to vmag2) is:
[code]
diff a/tsase/neb/util.py b/tsase/neb/util.py
--- a/tsase/neb/util.py
+++ b/tsase/neb/util.py
@@ -61,7 +61,7 @@ def vproj(v1, v2):
Parameters:
v1, v2: numpy vectors
- mag2 = vmag(v2)
+ mag2 = vmag2(v2)
if mag2 == 0:
printf("Can't project onto a zero vector", ERR)
return v1
[/code]
2) In both tsase/neb/pssneb.py and tsase/neb/ssneb.py forces calculation, when using dneb modification,
it has to multiply fsdneb by 2/pi * atan( |Fperp|²/|Fsperp|² ) but currently it multiplies by
2/pi * atan( |Fperp|/|Fsperp| ) (no squares). A patch to fix that bug (just changing vmag to vmag2) is:
[code]
diff a/tsase/neb/pssneb.py b/tsase/neb/pssneb.py
--- a/tsase/neb/pssneb.py
+++ b/tsase/neb/pssneb.py
@@ -334,8 +334,8 @@ class pssneb:
# New dneb where dneb force converges with (What?!)
if not self.dnebOrg:
- FperpSQ = vmag(self.path[i].fPerp)
- FsperpSQ = vmag(self.path[i].fsperp)
+ FperpSQ = vmag2(self.path[i].fPerp)
+ FsperpSQ = vmag2(self.path[i].fsperp)
if FsperpSQ > 0:
self.path[i].fsdneb *= 2.0 / pi * atan(FperpSQ / \
FsperpSQ)
diff a/tsase/neb/ssneb.py b/tsase/neb/ssneb.py
--- a/tsase/neb/ssneb.py
+++ b/tsase/neb/ssneb.py
@@ -409,8 +409,8 @@ class ssneb:
# dneb modification so that it will converge
if FsperpSQ > 0:
self.path[i].fsdneb *= 2.0/pi*atan(FperpSQ/FsperpSQ)
[/code]
Re: bugs in neb code
Wow, thank you very much! The error in the projection algorithm is particularly worrisome. Anyway, again, thank you for the fix. I've updated the code.
xph
Post by xph »
I was worried in the beginning, but later found out that all the "vproj" calls are projecting forces on to a unit vector (tangent direction), except in dneb. So dneb was totally messed up, but the regular (ss)neb was good.
