Is there any way to create non-overlapping images for NEB?
Posted: Sat Nov 17, 2018 9:21 am
Hi, VTSTTools
I'm trying to create images from trans to cis transition.
But some of the structures created in the image seem to cause a warning message.
| The distance between some ions is very small |
| please check the nearest neighbor list in the OUTCAR file |
| I HOPE YOU KNOW, WHAT YOU ARE DOING |
Is there any way to create images with non-overlapping of atoms automatically?
I saw a topic 'NEB initial image construction,' but I need more detail explanations.
I did "nebmake.pl POSCAR_trans POSCAR_cis 8", and attached just my initial(trans) and final(cis) POSCARs.
1. To create images with non-overlapping atoms, should I fix them manually?
2. In the TOPIC: NEB initial image construction, there is a tip that separate initial & final to initial, transition state & final.
How can I find the transition state? Is this correct that
Step 1: nebmake.pl POSCAR_trans POSCAR_cis 2
Step 2: And then, run NEB
Step 3: By using from the last results as the transition states, create more images
nebmake.pl POSCAR_trans POSCAR_TS1 2
nebmake.pl POSCAR_TS1 POSCAR_TS2 2
nebmake.pl POSCAR_TS2 POSCAR_cis 2
Step 4: Run NEB again with all eight images
But even in these steps, suppose they are correct steps, sometimes it causes overlapping images.
As getting complex initial and final images, it's hard to modify structures manually.
Best,
Noki
Best,
Noki
