IDPP interpolation using VTSTTools
Posted: Thu Nov 15, 2018 4:13 pm
by Abid
Hey guys,
I just joined this forum today. I'm trying to use IDPP interpolation in my NEB calculations. If I'm not wrong command 'nebmake.pl' gives linear interpolation ? . Is any one has experience using IDPP interpolation using VTSTTools . Thanks in advance
Re: IDPP interpolation using VTSTTools
Posted: Thu Nov 15, 2018 9:09 pm
That is correct. My understanding is that the IDPP method has been incorporated into ASE. Look for the idpp_interpolate method.
Posted: Fri Nov 16, 2018 12:13 pm
by Abid
Thanks for your reply. Yes you are right iddp is incorporated in ASE , then I need to use VASP calculator with interface of ASE if I need IDPP interpolation not VTSTTools ? .
Is it possible if I first go to linear interpolation by using VTSTTools and then use ASE to convert this linear interpolation to IDPP interpolation ?
Sorry for over questioning.
Posted: Fri Nov 16, 2018 1:20 pm
You can use ASE to generate the band with IDPP and then use either vasp or ase with a vasp potential to relax the band.
