NEB initial image construction
sinfire
Post by sinfire »
Hi all,
If the inital images constructed from nebmake.pl doesn't look right, would there be much problem if I tweak the constructed images manually to make a more reasonable path?
In that case, is there anything I need to consider when changing the images?
M.-C.
Re: NEB initial image construction
You can tweak them. Just try to keep them equally spaced.
Another trick you can use, if you have a guess for a transition state geometry, is to make a band out of two path segments, one from the initial state to the saddle point guess and the second from the saddle to the final state.
sinfire
Post by sinfire »
Thank you Prof. Henkelman.
Could you elaborate on making a band out of two path segments?
I can't find any parameters defining a band. Do you mean constructing N images using the Initial state and the TS guess and construct Max_image - N images using the TS guess and Final state?
yes
sinfire
Post by sinfire »
Thank you for the answer.
Regarding the distance, how close the distance between the images should be? (in other words, how many digits should I consider?)
Is 0.48 and 0.50 calculated from dist.pl close enough?
yes, fine.
