Extracting Hessian Matrix from OUTCAR file
itando01
Post by itando01 »
Hello
I performed a series of vibrational calculation in VASP using IBRION=5, and now i am looking for tools to extract the hessian matrix from the OUTCAR file i generated, in order to calculate thermodynamics properties. My question is two fold, are there script(s) for such task? and if so does one have to compile vasp code using vtst in order to use them?
Re: Extracting Hessian Matrix from OUTCAR file
With IBRION=5, vasp calculates the Hessian and the normal mode frequencies. Don't you just need the later for thermodynamic properties?
If you use the vtstcode, the dymmatrix.pl script generates the Hessian from forces printed in the OUTCAR file.
itando01
Post by itando01 »
Hello
Thanks a lot for your help, i haven't noticed that IBRION=5 writes out the eignvalues in OUTCAR, so all i need is there.
