How to get the minimum energy path?
kxshan
Post by kxshan »
dear sir
i have got the saddle point using dimer method. how to get the minimum energy path?
Re: How to get the minimum energy path?
You can minimize from two points displaced along the negative mode from the saddle point. The dimmins.pl script can be used to generate these configurations. Using a conservative optimizers (quick-min, for example) with a small MaxMove will give you more resolution along the path, if that's what you want.
