VTST and no output?
Posted: Sun Aug 03, 2008 6:13 pm
I have finally installed TST version of VASP on our MacOSX cluster. However, when I try to run it, it just produces a blank output and terminates. No errors, no warnings:
Some important points:
* The VASP without TST was working correctly
* The gamma point version (-DwNGZhalf ) worked OK (but that's not we want)
* When I use -DNGZhalf for the parallel multi k-point version, it fails.
* I compiled all TST-related files with NO optimization. The result was the same.
I would really appreciate your suggestions. We are looking forward to see TST running on our cluster!!
-Memo
Code: Select all
n99(0): POSCAR, INCAR and KPOINTS ok, starting setup
n99(0): WARNING: wrap around errors must be expected
n99(0): FFT: planning ... 1
n99(0): reading WAVECAR
All nodes terminated successfully.
-Memo
