Hello all
I generated a cube charge density file, however bader analysis code is giving me an error while trying to analyse it. The error i am getting is as follow:
OPEN ... density.cube
GAUSSIAN-STYLE INPUT FILE
At line 47 of file cube_mod.f90 (unit = 100, file = 'density.cube')
Fortran runtime error: Bad integer for item 1 in list input
Any help toward resolving this problem will be very much appreciated.
Cube File not working with Bader Analysis
Re: Cube File not working with Bader Analysis
If you post the problem file, I can take a look.
It is probably a memory issue. It runs fine on my laptop (see below). Either find a machine with more memory, or reduce the cell size, which appears to be ridiculously large.
OPEN ... chd.cube
DENSITY-GRID: 432 x 432 x 750
CLOSE ... chd.cube
RUN TIME: 49.45 SECONDS
0 10 25 50 75 100
REFINING AUTOMATICALLY
ITERATION: 1
EDGE POINTS: ********
REASSIGNED POINTS:15525876
RUN TIME: 450.27 SECONDS
0 10 25 50 75 100
RUN TIME: 38.64 SECONDS
NUMBER OF BADER MAXIMA FOUND: 6090804
SIGNIFICANT MAXIMA FOUND: 21
VACUUM CHARGE: 0.0000
NUMBER OF ELECTRONS: 30.00003
OPEN ... chd.cube
CLOSE ... chd.cube
0 10 25 50 75 100
ITERATION: 1
0 10 25 50 75 100
- ACF.dat.txt
- (1.21 KiB) Downloaded 1755 times
