NEB with VASP vdw correction
bzhangmse
Post by bzhangmse »
Hi, all!
Does anyone know whether vtst is compatible with VASP vdw correction (optB88-vdW)? I'm runing a NEB calculation. Unfortunately, it doesn't converge after almost 80 iteration. There are 14 images in total. I already check the bond length in initial images are not too short. I'm guessing the vdw correction in my INCAR may cause the convergence problem.
I really have no idea why it won't converge. Does anyone have a clue?
Many thanks!!
Re: NEB with VASP vdw correction
There should not be any coupling between VDW and the VTST code. Did you try to converge without the VDW interactions?
If you post the calculation, I can take a look at it.
