Do I need to compile Bader code into Vasp Code
itando01
Post by itando01 »
Hello Masters
I am pretty new in VASP community, and i was hoping to perform some bader analysis on molecular adsorption on surfaces for electrochem reactions. The first question i have is as follow: In order to perform bader analysis do i need to compile the code into VASP code!? I am currently using VASP 5.4.
Thanks for all your help.
Re: Do I need to compile Bader code into Vasp Code
No, you can use it to post-process the charge density files that vasp writes.
itando01
Post by itando01 »
Thanks for your reply. I appreciate all the help i can get.
Follow up question, from my readings i understand that in order to work properly i have to have both valence and core electrons, and need to set up: LAECHG tag in INCAR, is that a feature that is supported in Vasp 5.4?
Thanks again
Yes, it is.
itando01
Post by itando01 »
Thank you for all your help. I will give it a try!
