Visualising bader volumes
Vishal
Post by Vishal »
Hello Everyone out there,
The bader code when run gives bader volume as one of the output. So there must be a 3d surface associated with it right. I tried tracing out the surface but my algorithm was too primitive. So my question is, is there a way to actually visualise the bader surfaces that contain the different atoms ?
Re: Visualising bader volumes
Yes, you can write a charge-density-like file containing the atomic volume numbers (-p all_atom) or for a single atom (-p sel_atom). Then you can visualize the volumes using an appropriate choice of your isosurface value.
Vishal
Post by Vishal »
Hello Professor Graeme and Daniella,
Thanks for replying.
I have charge density file for O2 molecule.
Here is the Google drive link.
https://drive.google.com/a/smail.iitm.a ... p=drivesdk
Also the kind of surface I'm looking isnt isosurface at constant charge density value. Rather the surface which has points of charge density maxima along different possible directions. I believe this surface is the bader surface. Please correct me if I'm wrong.
