Getting confused with the direction of charge transfer
Re: Getting confused with the direction of charge transfer
Using the Bader analysis you can determine how much charge has been transferred from the Pt to the RGO. This gives you the magnitude of charge transfer and from which atoms and to which atoms the charge has moved. If you want a specific direction, then it sounds like you want to calculate a dipole moment, for which you do not need the Bader analysis.
