Thanks for your advices, sir
I remove the "-DMPI_CHAIN" from makefile and recompile the code. It does work. The calculation can normally run. But the DIMCAR is not same as result from
http://theory.cm.utexas.edu/vtsttools/dimer/ . Is the result right?
[zhoub@nsi dimrun]$ cat DIMCAR
1 3.26071 1.43918 -38.08043 -3.68085 7.47173
1 3.26071 0.36357 -38.08043 -3.92748 0.36588
2 0.65117 0.35142 -38.17788 -2.88998 2.09178
3 0.19376 0.27237 -38.19476 -2.84349 0.35374
4 0.22938 0.20858 -38.19339 -2.83961 0.24487
5 0.05342 0.64094 -38.19126 -3.08694 0.72768
6 0.02425 0.19128 -38.19128 -3.06311 0.46531
7 0.01777 0.34235 -38.19130 -3.10791 0.38655
8 0.00472 0.11193 -38.19130 -3.06178 0.16997
9 0.00199 0.16304 -38.19130 -3.03512 0.24693
10 0.00053 --- -38.19130 --- ---
[zhoub@nsi dimrun_complete]$ cat DIMCAR
1 3.26055 1.42551 -38.08043 -3.67928 7.32459
1 3.26055 0.47200 -38.08043 -3.89665 0.48560
2 0.65134 0.32662 -38.17792 -2.88463 1.05846
3 0.18678 0.22588 -38.19421 -2.88144 0.23646
4 0.20597 0.11406 -38.19315 -2.82977 0.14029
5 0.02071 0.58961 -38.19131 -3.08022 0.61217
6 0.01329 0.06599 -38.19131 -3.05717 0.14982
7 0.00990 0.11718 -38.19130 -3.07347 0.26844
8 0.00208 0.11183 -38.19130 -3.04074 0.14479
