charge analysis with orbitals
nigma
Post by nigma »
Dear all:
I want to analyze charge distributions on atoms by spatial and orbitals.
For example, in CO2 case, 2 electrons in C=O bonds are contributed by 2p orbitals of per oxygen.
I am wondering whether I could use Bader to do this work and how.
Re: charge analysis with orbitals
The closest thing that I can think of is a partitioning of the local density of states into Bader volumes, as described in the attached paper.
gudmundsdottir12_164705.pdf
(2.15 MiB) Downloaded 1660 times
nigma
Post by nigma »
Is there any way to know s,p,d... orbitals and their linear combination under DFT calculation? Like Gaussian can find out molecule orbitials.
Also, thankyou for answering my question Dr.graeme.
Codes such a vasp will project the density of states into spherical harmonics around each atom. In this way you can have some measure of the s, p, d, .. components. It will not be as sophisticated, however, as a natural orbital analysis that you might use with Gaussian.
nigma
Post by nigma »
ok, thanks!
