about the use of nebconvergence.pl
hakuna
Post by hakuna »
Dear all:
if nebconvergence.pl tell me:
In 01 ...
497
mv: cannot stat 'vaspout1.eps': No such file or directory
In 02 ...
497
mv: cannot stat 'vaspout2.eps': No such file or directory
In 03 ...
497
mv: cannot stat 'vaspout3.eps': No such file or directory
In 04 ...
How to deal with it? which script can generate the 'vaspoutx.eps' ?
by the way, the vtstscripts was unzipped to ~hakuna/bin/vtstscripts-933 and the path was defined in .bashrc as
PATH=~hakuna/bin/vtstscripts-933:$PATH
is it ok?
thanks
Re: about the use of nebconvergence.pl
Start by making sure that you have gnuplot installed.
If you do, and you still have problems, you can attach a .tar.gz of the NEB calculation, I will see if something went wrong with it.
