TS from dimer method - making sure it connects reactant/product
arosen
Post by arosen »
Is there any way to confirm that a TS found via the dimer method (e.g. after a rough NEB run) does indeed connect the proposed reactant and product?
Re: TS from dimer method - making sure it connects reactant/product
You can make small displacements forward and backwards along the negative mode at the saddle and then minimize these two configurations. We have a script called dimmins.pl to set up these calculations.
arosen
Post by arosen »
Fantastic, thank you! That will work perfectly.
