the structure does not converge
Posted: Thu Aug 03, 2017 1:16 am
by weiyidan
Hi professor,
I prepare to do a calculation than a atom moves in the surface between the two bulk.
First, i use Ediff=1e-2, Ediffg=-0.3, IBRION=2, it works well.
Second, i use Ediff=1e-5, Ediffg =-0.05, IBRION=2, it works well too.
Third, i use Ediff=1e-5, Ediffg =-0.01, IBRION=1, the problem appears.
when I relax the heterojunction with parameters in the third step, it seems hard to converge. What is the problem? Can you give me some advice?
My calculation history is in the attachment.
Thanks for your attention.
Yidan WEi
Re: the structure does not converge
Posted: Thu Aug 03, 2017 1:55 am
Try lowering POTIM; a value of 0.3 is pretty large for IBRION=1.
Posted: Thu Aug 03, 2017 7:25 am
by weiyidan
how about POTIM=0.15?
Posted: Thu Aug 03, 2017 3:33 pm
I typically use 0.1, but it really depends upon the stiffest mode in your system. You can try a few values to see when the convergence stabilizes.
Posted: Fri Aug 04, 2017 4:59 am
by weiyidan
Thanks for your reply, as You help me a lot from last year to now.
Concerning to the problem,
1. I used POTIM=0.15, however , it did not work. I attach the calculation files in attachments and the picture shows the relationship between energy and steps. Should I use a smaller POTIM?
2.how to judge the stabilization of convergence ? is continuous decrements in energy?
Yidan Wei
Posted: Fri Aug 04, 2017 5:00 am
by weiyidan
here is the attachment
Posted: Mon Aug 14, 2017 4:04 am
I was not able to use the built-in IBRION=1 vasp LBFGS to obtain good convergence. My best attempt is here:
cy1.tar.gz
(44.66 MiB) Downloaded 33813 times
Using quick-min (IBRION=3) did better, but did not converge within 200 iterations:
cy2.tar.gz
(27.24 MiB) Downloaded 33615 times
I expect that quick-min would converge, but using our LBFGS optimizer (IBRION=3, POTIM=0, IOPT=1, INVCURV = 0.002) does a good job:
cy5.tar.gz
(20.86 MiB) Downloaded 33792 times
Posted: Mon Oct 09, 2017 2:08 am
by weiyidan
Thanks,professor. You really help me a lot.
