i am working on getting TS regarding CO oxidation reaction on metal surface using CI-NEB calculation.
however, after so many steps, image 4, 5 forces doesn't seem to be converged. it fluctuate
I am not sure whether it is structure problem or input problem.
my first try was that
I used 8 images
POTIM = 0.01
EDIFFG = -0.1
but the forces didn't converge, after that i switch to this input
IBRION = 1
POTIM = 0.1
EDIFFG = -0.1
and waiting the result
my question is that should i change other tags? or consider other intermediate images?
I attached INCAR, and POSCARs just in case.
Thank you
Sincerely,
WoonghyeonPark
NEB force converge problem
- neb.zip
- (19.18 MiB) Downloaded 795 times
Re: NEB force converge problem
First, make sure that all of your frozen atoms are in exactly the same positions in all of your images.
Then, try using IBRION=3 POTIM=0.1 until your forces get to around 0.1 and then you can try switching to (for example) IBRION for faster convergence.
