I am doing Bader charge analysis with a spin polarised CHGCAR. When I do the usual Bader CHGCAR -ref CHGCAR_sum, it works fine, however when I use the chgsplit.pl on CHGCAR to get CHGCAR_mag and then do Bader CHGCAR_mag -ref CHGCAR_sum, I get the following error.
"CALCULATING BADER CHARGE DISTRIBUTION
0 10 25 50 75 100
REFINING AUTOMATICALLY
ITERATION: 1
EDGE POINTS: 223892
ERROR: should be no new maxima in edge refinement
I have attached the two CHGCAR files(CHGCAR_mag,CHGCAR_sum) here.[attachment=0]CHGCAR_sum.zip[/attachment][attachment=1]CHGCAR_mag.zip[/attachment]
Could you please check and let me know what went wrong ?
Thank You.
Bader analysis-spin polarised error
- CHGCAR_sum.zip
- (53.26 MiB) Downloaded 1546 times
- CHGCAR_mag.zip
- (48.45 MiB) Downloaded 1504 times
Re: Bader analysis-spin polarised error
I don't think that this is a significant problem. If you turn off the vacuum charge, the partitioning should be the same for the CHGCAR and the CHGCAR_mag. Specifically, if you run the command below, the partitioning will be similar (while the ACF.dat values will be different) as compared to "bader -vac off CHGCAR -ref CHGCAR_sum"
bader -vac off CHGCAR_mag -ref CHGCAR_sum
OPEN ... CHGCAR_mag
VASP5-STYLE INPUT FILE
DENSITY-GRID: 96 x 448 x 180
CLOSE ... CHGCAR_mag
RUN TIME: 3.08 SECONDS
OPEN ... CHGCAR_sum
CLOSE ... CHGCAR_sum
RUN TIME: 3.14 SECONDS
0 10 25 50 75 100
ITERATION: 1
EDGE POINTS: 3323174
REASSIGNED POINTS: 117145
ITERATION: 2
CHECKED POINTS: 1523896
REASSIGNED POINTS: 199
ITERATION: 3
CHECKED POINTS: 3737
REASSIGNED POINTS: 6
ITERATION: 4
CHECKED POINTS: 156
ITERATION: 5
CHECKED POINTS: 26
REASSIGNED POINTS: 0
RUN TIME: 27.36 SECONDS
0 10 25 50 75 100
RUN TIME: 2.23 SECONDS
NUMBER OF BADER MAXIMA FOUND: 13699
SIGNIFICANT MAXIMA FOUND: 43
VACUUM CHARGE: 0.0000
NUMBER OF ELECTRONS: 4.00075
the analysis will be similar
OPEN ... CHGCAR_mag
OPEN ... CHGCAR_sum
0 10 25 50 75 100
ITERATION: 1
ITERATION: 2
ITERATION: 3
ITERATION: 4
CHECKED POINTS: 156
ITERATION: 5
CHECKED POINTS: 26
0 10 25 50 75 100
Thank You Sir.
