Dear NEB users,
I want to calculate the reaction barrier for a reaction, which has 3 reactants, like A + B + C ---> D.
Can I calculate it directly? Or I have to break down the reaction into different steps, like A + B ---> E, then E + C ---> D. And calculate the barrier for each reaction?
Thanks, Yu
Can you calculate the reaction barrier for a reaction with 3 reactants directly using NEB?
Re: Can you calculate the reaction barrier for a reaction with 3 reactants directly using NEB?
You can certainly set up NEB calculations based upon whatever assumed reaction mechanism that you think is feasible. That said, the algorithm will relax to a minimum energy path crossing first-order saddle points, so if there is no single saddle for a reaction (e.g. A + B + C ---> D, which by the way, I think is very unlikely to exist) the NEB will relax to the nearest actual reaction pathway (e.g. A + B ---> E, then E + C ---> D).
Yes its very easy . I thinks you are do it
and is very unlikely to exist) the NEB will relax to the nearest actual reaction pathway (e.g. A + B ---> E, then E + C ---> D).
More Learning visit
[URL="http://skillonpage.com"]self skill learning[/URL]
More Learning visit
