Question about split_dos
flyhigh
Post by flyhigh »
Recently, I downloaded the scripts "vtstscripts.tgz".
I calculated d-band center of Pt surface with this, and I got the results below.
Only Emax is different in the case (1) and the case (2).
I do not understand the meaning of the last message,"Can't take sqrt of -415.985 at /bin/vtstscripts/dosanalyze.pl line 292."
Why did it make problems to increase Emax?
Logically, it does not seem to have problems.
In other words, how can I decide the range of Emin and Emax?
Average Energy (band center) is affected by the range of Emin and Emax too much.
Any advice would be welcome.
Thanks.
case (1)
$ dosanalyze.pl e=-7,0 d
Integrate from -7eV to 0eV.
WARNING: For DOS0, ALL bands are analyzed
WARNING: band center has shifted by more than 10% compared to full integrated range
Total States: 69.43606769
Average Energy (band center): -2.25169355987311
Standard Deviation: 2.48325612734491
case (2)
$ dosanalyze.pl e=-7,1 d
Integrate from -7eV to 1eV.
Re: Question about split_dos
If you can post the directory with the data, I'll try to reproduce the problem and find a solution.
flyhigh
Post by flyhigh »
[quote="graeme"]If you can post the directory with the data, I'll try to reproduce the problem and find a solution.[/quote]
I checked the script "dosanalyze.pl ", and I found the error message is related to the variance.
290 $eneavg = $dstsum/$dossum;
291 $enevar = ($dssqsum*$dossum - $dstsum*$dstsum)/($dossum*$dossum);
292 $enestd = sqrt($enevar);
In case I used ISPIN=2 in INCAR file, can this problem be caused by this?
If I can see the files that you are analyzing, I should be able to debug this.
