Is Solid-state dimer method available?
dft_imr2
Post by dft_imr2 »
Dear Prof. Graeme
I want to research the solid-solid phase transitions use the Solid-state dimer method. Is it available in VTST tool?
Thank you for all your help.
Re: Is Solid-state dimer method available?
Yes, it is implemented in the tstcode that can be linked into vasp. It is also in the tsase package which is a python extension of the atomic simulation environment, for which there are many calculators including lammps and a variety of DFT packages.
dft_imr
Post by dft_imr »
Dear Prof. Graeme
Thank you for your help.
Do I need to make some Settings to make the Solid-state dimer method work?
set LNEBCELL = .TRUE.
dft_imr2
Post by dft_imr2 »
For a changing cell, use LNEBCELL=TRUE. And then,the SSNEB and SS-dimer method all need to set IOPT=3? Am I free to choice the optimizer ?
you can choose the optimizer
dft_imr2
Post by dft_imr2 »
Thank you for your help again
dft_imr2
Post by dft_imr2 »
[quote="graeme"]Yes, it is implemented in the tstcode that can be linked into vasp. It is also in the tsase package which is a python extension of the atomic simulation environment, for which there are many calculators including lammps and a variety of DFT packages.[/quote]
Dear Prof. Graeme
I used the Solid-state dimer method to calculate solid-solid phase transitions, but I find that the lattice vector was not change when use LNEBCELL=TRUE.
This is my INCAR
ISYM= 0
SYSTEM= Ti
ISTART= 0
ICHARG= 2
ISMEAR= 1
SIGMA= 0.2
EDIFF = 1.00E-04
EDIFFG = -0.02
PREC = Medium
LWAVE = .FALSE.
LCHARG = .FALSE.
ENCUT = 450.000000
NSW = 1000
ISPIN = 1
NELM = 100
NBANDS= 96
IMAGES = 3
SPRING = -5
LCLIMB = .TRUE.
LNEBCELL = .TRUE.
IOPT = 3
MAXMOVE = 0.05
POTIM= 0
ISIF= 3
GGA= PE
LREAL= Auto
IALGO= 48
LPLANE = .TRUE.
NPAR = 2
LSCALU = .FALSE.
NSIM = 4
If you post your calculation I can debug it.
dft_imr2
Post by dft_imr2 »
[quote="graeme"]If you post your calculation I can debug it.[/quote]
[attachment=0]Ti_reorientation.rar[/attachment]
(143.05 KiB) Downloaded 940 times
dft_imr2
Post by dft_imr2 »
This attachment is my calculation .
