Dear Sir,
I have compiled vasp.5.3 with your VTST Code successfully. However, when i am trying to do a NEB calculation, the job finishes abruptly, although other vasp jobs run successfully with this compiled vasp binary. I am attaching a tar file of my calculation directory. Kindly look into it and suggest me where i am going wrong.
Best Wishes & Regards,
Manzoor
NEB calculation Problems
Re: NEB calculation Problems
Please find the attached tar directory.
- NEB.tar
- (210 KiB) Downloaded 1089 times
You could use our TSASE code, which uses forces and energy from LAMMPS. In this way you can use our NEB (which will not enforce minimization of the endpoints) with the same forces and energy that you are using in LAMMPS.
