How to compile vtstcode into vasp.5.3.5?
hongyi
Post by hongyi »
Hi all,
I obtain the latest vtsttools as follows:
svn co http://theory.cm.utexas.edu/svn/vtsttools
Then, I try to compile the vtstcode into vasp.5.3.5, but I can find the following two patches in the source directory:
vasp-5.3.2-main.patch
vasp-5.3.2-mpmd.patch
As you can see, the above two patches are not match with the vasp version I want to compiled into. Any hints
for this issue?
Regards
olemiss
Re: How to compile vtstcode into vasp.5.3.5?
Post by olemiss »
The patches work on main.F and mpi.F. Only the patch file for main_mpi.F has a little issues. I have manually patched the required files. It won't take you too much time.
