which VTST version to compiled with VASP
hakuna
Post by hakuna »
Dear all vtstcode developer:
the vtstcode guide says the 3.1 version can be compiled with VASP 5.3.X, then if we compiled it with old VASP versions, say version 4.6, which version of the vtstcode should we use ? where can we find the old versions of the vtstcode ?
thanks
Re: which VTST version to compiled with VASP
You can find the old versions of the vtstcode, as well as installation details at this old webpage:
http://theory.cm.utexas.edu/vtsttools_old/
hakuna
Post by hakuna »
thanks prof. Graeme
can we have the elder brother version of v2.04d, about 5~7 years old
no problem. Here is a link to all the older versions
http://theory.cm.utexas.edu/vtsttools_o ... tcode_old/
hakuna
Post by hakuna »
that is great! thanks again
huyaoqiao
Post by huyaoqiao »
[quote="graeme"]no problem. Here is a link to all the older versions
http://theory.cm.utexas.edu/vtsttools_o ... tcode_old/[/quote]
hello. My vasp version is 5.2, and which version of vtst code can I build into the vasp?
you can build with the latest version of vtst
huyaoqiao
Post by huyaoqiao »
[quote="graeme"]you can build with the latest version of vtst[/quote]
Another question. To build the code, the VASP makefile needs to be changed, but I couldn't find the makefile, in my directory vasp-code/vasp.5.2, there are just makefile.* like makefile.dec, makefile.hp, etc, so which file do I need to choose? Also,the objects dynmat.o and the optimizer objects sd.o don't appear in thr source list. I am now using the stampede.
