Dear VASP user community,
Greetings. Please find the Band.pptx file attached herewith.
In our VASP calculations, MoS2 monolayer nanosheet shows a direct band gap at the k-point, K corresponding to the supercell shown in Slide 1, while direct band gap is observed at the k-point, A for the supercell with a different symmetry shown in Slide 2. The results in Slide 1 is in agreement with the reported findings. Different set of k points have been chosen in the band structure calculations for the two different symmetries in the supercells shown in the two slides. Calculations have been done using PAW_GGA-PBE.
Any help will be most sincerely appreciated.
Thanking you.
With my Best Regards,
Direct band gap at wrong k point on MoS2 monolayer nanosheet
- Contact:
- Band.pptx
- (824.93 KiB) Downloaded 1006 times
Re: Direct band gap at wrong k point on MoS2 monolayer nanos
This question is better suited for the vasp developers: http://cms.mpi.univie.ac.at/vasp-forum/forum.php
This site is specifically for transition state theory related questions.
