VASP5/VASP4
Re: VASP5/VASP4
It should, if you have the vtstcode linked in. If there is a problem, and you post an example, we can look into it.
Re: VASP5/VASP4
sure, use gzip or bzip2. In fact, best would be to tar the entire directory, excluding the WAV* CHG* files, and then compress and attach that to a post (attach the file, don't try to post a bunch of OUTCAR text!). That way, if the script gets information from other files, I can reproduce it.
