newcomer: DIMER METHOD WITH VTST
perez
Post by perez »
hello
I have been looking at the dimer-method example provided with the VTST distribution
and, as a newcomer, I would like to understand one point that is not clear
please let me know why when you grep the total energy inside OUTCAR, you can see that
it going down, and the final energy is the lowest of all
In my undestanding, with the dimer method we are computing a maximum in total energy,
therefore, the final (dimer-converged) energy should be the highest of all (less negative)
thank you for your understanding
regards
Manuel
Re: newcomer: DIMER METHOD WITH VTST
The total energy will not be a local maximum or minimum with the dimer method since it is converging to a saddle point. Instead, it is the force that should systematically drop as the dimer converges to the saddle.
