non linear interpolation for NEB???
stsh
Post by stsh »
Hi
I have for example HCN which also has a possible configuration as CNH. In this case, if I use linear interpolation, I will have, for some images very close atomic positions for C and N. So I was thinking if there are some other interpolation tools to account for cases where linear interpolation fails.
For this case, if I need to make some script for getting the images, what would you suggest?
Thank you for your time.
Re: non linear interpolation for NEB???
A quick solution is to run our nebavoid.pl script, which will push the atoms apart along the band to somewhat physical lengths.
A second thing to look at is some recent work by Hannes Jonsson:
'Improved initial guess for minimum energy path calculations', S. Smidstrup, A. Pedersen, K. Stokbro and H. Jónsson, J. Chem. Phys. 140, 214106 (2014)
and a link to the manuscript:
http://arxiv.org/abs/1406.1512
stsh
Post by stsh »
Thank you so much. You are amazing :)
