Hi
I have a basic question on how to link VASP. I get the following error when I run nebmake.pl as follows:
$./nebmake.pl POSCAR1 POSCAR2 9
This is what I get as error
$Can't locate vasp.pm in @INC (@INC contains: /research/dir/ch6/neb /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at ./nebmake.pl line 8.
BEGIN failed--compilation aborted at ./nebmake.pl line 8.
Also I don't exactly know which directory to feed into PATH variable. The vtsttools.tar.gz has all the files as fortran files. So if I link PATH to this fortran files containing directory, what difference will it make when running any script? Also I had to get the nebmake.pl separately from your vtst repositories. Confused...
Thanks for any help
nebmake.pl
Re: nebmake.pl
Sorry. I don't know why, but I put in Vasp.pm script in the working directory and everything looks fine.
Re: nebmake.pl
You should download all of the scripts into one directory, put that directly into your path, and run them from there. Then, they will be able to find each other.
