Force is not going below 0.1 eV/Å in my NEB calculation
riyazpu
Post by riyazpu »
Dear All
I am doing an NEB calculation for N-O dissociation barrier on a metal surface. First, I used IBRION = 3, IOPT=3, POTIM = 0 and TIMESTEP = 0.03, and force converging until 0.1 eV/Å and not going down. Then I increased the TIMESTEP to 0.1 and restarted the calculation but the force is not converging. I also changed IOPT to 2nd order optimizer IOPT= 1 and 2 but still, the force is not stabilizing. Can anyone suggest a solution to the problem? As I already stated, I tried different solutions provided in this forum but had no luck.
I have attached the input I used.
Thank you
Best
Riyaz
neb.tar.gz
(453.51 KiB) Downloaded 23010 times
Re: Force is not going below 0.1 eV/Å in my NEB calculation
I don't see any OUTCARs - I need them to see what is going on.
riyazpu
Post by riyazpu »
Thank you for your response, I have attached the folder with OUTCARs, please have a look.
Thank you for your time.
neb.tar.gz
(34.63 MiB) Downloaded 23471 times
It's converging - you just have a small timestep of 0.03. You can up to a value of 0.1 and continue the calculation.
riyazpu
Post by riyazpu »
Though I tried timestep 0.1 and the force started to destabilize. But yes I will try again. Another question is, should I rather try a dimer calculation, when the force reaches around 0.1 eV/Ang with CL-NEB or continue with CL-NEB and converge the force?
Thank you
just get this to converge before you try anything more fancy. And check that you have the same settings in your NEB as compared to the endpoints - I see a disconcerting shift in the entire top layer between the neb images and the final structure.
riyazpu
Post by riyazpu »
Ok..Thanks for the tips and yes I also see a bit of a shift in the surface atoms during optimization.
