Humongous tasks, miniscule credits
NZjelle
Post by NZjelle »
I just ran a number of tasks that took almost 2 hours to complete, on an Intel i7-3770 CPU running at 3.4GHz, and provided 0.99 (that is less than 1) credit. What gives?
Gibson Praise
Re: Humongous tasks, miniscule credits
Post by Gibson Praise »
Something strange is going on, I agree. Units that won't end, or run for hours. Both intel and AMD chip
bones cruncher
Post by bones cruncher »
I'm getting these too on my Intel(R) Core(tm) i5-3450 CPU @ 3.10GHz.
WU used to take 6-8 minutes. Now I have 4 that look like they will be passing the 7 hour mark.
bones cruncher
Yippe, two just completed and gave me 12.81 credits compared to the .90 that I usually get. Taking about 70x as long but only get 13x the cobblestones. I wonder if these longer WU are less efficient for some reason.
Conan
Post by Conan »
I have had 7 work units that now have taken many Hours to run not a few munutes as normal.
Windows 32 bit computer (AMD Phenom II X6 1100) ---- Normal run time 180 to 520 seconds and 15 cr/h ave
232055284 27,007.34 seconds (7.50 hours) for 2.66 credits (0.35 cr/h)
232055283 27,179.34 seconds (7.55 hours) for 12.69 credits (1.68 cr/h)
232055282 27,171.22 seconds (7.55 hours) for 12.69 credits (1.68 cr/h)
232055281 27,157.70 seconds (7.54 hours) for 12.69 credits (1.68 cr/h)
Linux 64 bit computer (AMD Phenom II X6 1090) Normal run time 140 to 410 seconds and 30 cr/h ave
232056812 13,307.30 seconds (3.70 hours) for 2.01 credits (0.54 cr/h)
232056120 13,306.62 seconds (3.70 hours) for 100.81 credits (27.27 cr/h)
232053969 13,314.59 seconds (3.70 hours) for 58.18 credits (15.73 cr/h)
Other than one of the results (on Linux) all the results give bugger all points for the long run times.
The Windows work units seem to have a credit limit at 12.69, which for a 7.5 hour WU is lousy and hardly worth the effort (32 bit credit on my Windows machines is already very low at 15 so going down to less than 2 is not funny)
Can we have an answer as to what is going on please?
Conan
Conan
Post by Conan »
Well I finished another 7.5 hour Windows work unit today the 21/6/13 (it's the 21st in Australia) and got very little reward for it.
Since the last long work unit has been completed EVERY WORK UNIT NOW FAILS with the following ERROR
<message>
The system cannot find the path specified. (0x3) - exit code 3 (0x3)
</message>
<stderr_txt>
17:59:14 (7288): No heartbeat from core client for 30 sec - exiting
18:00:03 (6488): No heartbeat from core client for 30 sec - exiting
terminate called after throwing an instance of 'std::bad_alloc'
what(): std::bad_alloc
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
For example see WU 232102339 and WU 232102927
This only started today (21st June) all work unit OK up till the 20th then the long work units now all errors.
Have done another WU on Linux it was successful but longer than normal (over 1800 sec) waiting to see if I get Linux errors when I get some more work.
Conan
Matthias Lehmkuhl
Post by Matthias Lehmkuhl »
One important additional point: there is no restart from a checkpoint for this long running WU.
For a runtime longer than a hour this is not usable for me.
I had some results, that run more than 6 hours and start from beginning after a new boot of the machine.
And the restart is not visible in the Stderr output
Oh, and I've just seen, abort of a WU causes a crash:
<core_client_version>7.0.64</core_client_version>
<![CDATA[
<message>
aborted by user
</message>
<stderr_txt>
Unhandled Exception Detected...
- Unhandled Exception Record -
Reason: Breakpoint Encountered (0x80000003) at address 0x749D3219
Engaging BOINC Windows Runtime Debugger...
Balmer
Post by Balmer »
Hello ...
Something is wrong.
Too Long Tasks (or not ending Tasks or ...).
5 to 10 Minutes Tasks are OK.
AND WE WANT GPU SUPPORT (ATI and NVIDIA).
Best Greetings
Balmer
Switzerland
