NEB convergence problems
Posted: Mon Jun 12, 2023 8:32 am
Dear Prof. Henkelman,
I am trying to do a cNEB calculation of CO oxidation on Pt single atom anchored on perovskite. I use IOPT = 3, TIMESTEP = 0.01, EDIFF = 1E-5 at first, to make the forces drop to around 0.5 eV/Ang systematically, and this set up work effectively to drop the high forces. However, when I use a more strict convergence set up(IOPT = 3,TIMESTEP = 0.05, EDIFF=1E-7, EDIFFG= 0.1), the force only fluctuate between 0.15~0.5 ev/ Ang. Is there any suggestion to make the structure converge better, or is it just unnecessary to converge any more?(because the energy barrier doesn't be changed radically, and there is reasonable imaginary frequency, as you can see in my given example)
I also tried to use IOPT = 2 or (IOPT=3, TIMESTEP = 0.1) in the fine convergence(EDIFF = 1E-7), but it seems that the force will eventually rise up to above 1 eV/ Ang, especially in the middle images, and there would even be two energy highest point in the reaction path in some canses. Can you explain why would this happen?
I have attached a .tar.gz file with all the data used. It will be of great help if you could take some time to have a comment.
Yours sincerely,
Yours sincerely,
